- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
While trying to use the "File" drop down menu and sometimes other tabbing, the window will literally close for 1/10 of a second or so then pop back open. Like a flicker effect. It's not only annoying as heck, if I were epileptic I'd be having seizures.
I searched for and found a solution from 2018. Here:https://knowledge.autodesk.com/support/featurecam-products/troubleshooting/caas/sfdcarticles/sfdcart...
I did as suggested to no avail. I still have the flicker.
I also noticed that although I'm able to change the parameters, the software is changing it as well. My display resolution is 2560 x 1080, and I'll change it, but it gets changed to 2561 x 1081... Not much, but still I get the flicker.
¡Resuelto! Ir a solución.
