Hello, I have a problem with the simulation of a toolpath feature created by an add-in. The toolpath points all seem to have been created correctly (X, Y, Z, I, J and K are correct when the problem occours), but in the simulation the position of the workpiece is suddenly changed at one point, causing the cutter to pass through the workpiece. Five axes are used and instead of rotating the workpiece, it is repositioned around the cutter and then milled correctly. Does anyone have any idea what the problem could be?
