Material Database in Partmaker is lacking
I just started using Partmaker 2018 and I found that the material list in the swiss setup is not very extensive. The material list in Featurecam is quite extensive however and I was wondering if there was a simple way to import the Featurecam material list into Partmaker Swiss and Turn/mill programs.
Did you ever find a solution to this question? I'm just beginning to set up our material library/build on the existing library provided by PM, but I feel that the material data prompt is lacking in order to create or modify a library.
