Lathe I.D. groove
Lathe I.D. groove
No aplicable
I am trying to machine a I.D. groove on a Haas lathe. my co worker drew the insert configuration and used that for the insert shape, can anyone tell me how this works, and why when i run the simulation the tool over and under cuts the part? I have been trying to watch videos on this but i need to get work done.
0 Me gusta
Responder
Soluciones aceptadas (2)
485 Vistas
5 Respuestas
Respuestas (5)
No aplicable
I started a new test program, created a I.D. groove, the end is wider that the opening, the tool has a bigger angle on it that the id groove but i cant seem to get the groove tool to follow the curve i created for the id groove, the tool just goes straight , any ideas on how the get the groove to to follow the gemoetry?
0 Me gusta
gabriele.esposito
Hi joel. stanfield2, could you please attach the Featurecam project and the tool geometry?
Regards
Gabriele Esposito
Sr Technical Support Specialist
Autodesk Make | Autodesk Knowledge Network | Autodesk Advanced Manufacturing | Autodesk Fusion 360
0 Me gusta
No aplicable
Solución aceptada
I am not allowed to send anything out.
0 Me gusta
gabriele.esposito
Unfortunately without (at least) the tool I can not help you, I would have given you some links where you can see how to create custom tools, but this you have already said that you did not need.
I'm sorry
Gabriele Esposito
0 Me gusta
No aplicable
Solución aceptada
I worked with DEV at autodesk, he showed me that to machine the groove configuration i wanted i would have to use a boring bar operation. its not exactly what i want for a tool path but it works.
