How to create turning tool with inclination angle
rdbojan
rdbojan
Hi all,
I need some help with how to represent this turning tool in FeatureCAM.
I don't have so much experience with turning.
I presume that it needs to be approximated.
Here is a link to this tool:
https://www.secotools.com/article/p_02413804
What is the best practice to create this tool?
Thank you in advance!
rdbojan
This is what I get so far:
rdbojan
Somebody from Autodesk?
ChristopherMarion
@rdbojan
The tool needs to be created at the stock axis location from the tip of the tool.
Here is an article that explains this that has a video for reference.....https://knowledge.autodesk.com/support/featurecam-products/troubleshooting/caas/sfdcarticles/sfdcart...
Let me know if this helps.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
rdbojan
Hi @ChristopherMarion ,
Thank You for your answer.
I have watched this video and I had doubts about approximation because of the inclination angle.
I just used now the height of insert, but from the tip of the insert. I hope that this is wright.
Adjusted.jpgMeasured insert heightMeasured insert heightMoved holderMoved holder
