how can I use FC for cuntinuous 4th axis machining
Message 1 of 18
Okay I have a simple enough part it's just an oval with about 20 90deg grooves that go around it. They are only about .015" deep I could write a program by hand that would do this easily but I have not been able to get FC to do it it either wants to try to do it as surface milling or gives me errors. Anyone have a thought on what am I missing?
Accepted solutions (3)
Replies (17)
Message 2 of 18
Hi @Anonymous,
Can you share the part?
Message 3 of 18
here you go this is the part the main reson I want to do this on the indexing head is it is hard to find double angle cutters this long that come to a small enough point.
Message 4 of 18
Hi @Anonymous,
Is it around this I have marked "red"?
Message 5 of 18
Hi @Anonymous,
See the attached file. NOTE you I have used mm tools.
Message 6 of 18
Missing attachment so I can't tell what you marked in red. but probably there are a bunch of grooves going around it and that go down the length of it. It seams like it should be a simple part to make completely on the 4th axis cut the bottom off and machine the inside in a second op an be done. otherwise you end up with more setups. setups are time time is money
Message 7 of 18
thanks JD i'll take a look and see what you did and get back to you in a few mins.
Message 8 of 18
Thanks JD,
this works great but how did you go about it? Yesterday I had put a the surface on it like you did but rather than indexing it would just surface mill straight down without indexing around the part. I have a couple other sizes to do so need to under stand how to make it work. in the mean time I will continue looking at all your settings etc. and see if I can pick up what I've been missing.
Message 9 of 18
Hi @Anonymous,
If you can wait 2 hours, then I will made a video with the steps.
Message 10 of 18
awesome thanks
Message 11 of 18
bhorstTGM48
Message 12 of 18
Hi @Anonymous,
Here you go, I hope I can explain in teh video so you can understand:-)
https://autode.sk/2qrk8ye
Message 13 of 18
Okay I missed that before, so I have tried it on  the grooves but it is still doing funny things like going way deeper than the surface indicated and then continuously indexing while the z goes up a couple thousandths at a time and X+ a couple at a time. gonna keep playing with it I never give up
Message 14 of 18
thanks again JD
Message 15 of 18
Hi @Anonymous,
I will take a look in the groove issue:-)
Message 16 of 18
bhorstTGM48
Message 17 of 18
rfuentes
is this for lathe or mill
Message 18 of 18
I am doing it on a mill and have it finished now thanks to JD and bhorstTGM48. Thanks you guys
