How can air cutting be eliminated when milling a tube from the side
No aplicable
I have a tube that has some windows cut out of the side of it.
When I create a toolpath for a feedmill to pocket out the window, there is a massive amount of wasted time, cutting air.
I have the stock defined as a tube...
0 Me gusta
Responder
Soluciones aceptadas (1)
401 Vistas
2 Respuestas
Respuestas (2)
abhishek.juvekar
Solución aceptada
Hi @Anonymous,
Thanks for raising your query via Autodesk Forum.
Can you please verify the part or a solid stock a valid solid? You can verify that via Construct > Verify solid. Did you also try using stockmodel? If you can supply the part, I can take a look.
Thank You.
Abhishek
0 Me gusta
No aplicable
This worked for the "side" feature toolpath, and kind-of worked for the "pocket feature".
Still working on an efficient toolpath for this... But thanks this did help
0 Me gusta
