No aplicable
06-04-2018
11:13 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Goodmorning,
we often use high feed mills for roughing operations. In our experience this kind of mills suffer greatly during the transition from air cutting to material cutting, so as long as we do machine closed pockets with ramp-in there are no problems, but when we do sides or open pockets we have to greatly reduce cutting parameters to avoid insert failure. Is there a way to instruct FeatureCam to slow down feed upon material entering, untill the mill is fully on the stock before restoring the programmed feed?
Thank you.
¡Resuelto! Ir a solución.
