G98/99 posting
G98/99 posting
m.laplante.gm
Message 1 of 11
G98/99 posting
m.laplante.gm
My post doesn't ouput G98/99 even if <CYCLE-RTRCT> is in my post. It leaves a blank space on my G-code line.
When I post with a generic Fanuc post, I do have the G98/99 in my G-code.
It seems like something else is blocking it.
Does someone have a idea?
Thanks!
Max
Replies (10)
Message 2 of 11
chris.coleQDYFL
Hi, Max.
Here are a couple things you can look at:
First, make sure the G98/G99 codes are entered into the post. In Xbuild, go to CNC Info > NC Codes and make sure they are there.
Next, make sure you are using "Combine similar holes into canned cycle" in the Strategy tab of the feature. If that's a setting you want all the time, make sure it is enabled on the Drilling tab of your Machining Attributes/Configurations.
That should do it. I hope that helps.
Chris Cole
Senior Solutions Engineer
Message 3 of 11
m.laplante.gm
Hi Chris,
My G codes in Xbuild are defined and my strategy is the same as on your screen shot.
As you can see on my screen shot,  I'm posting a blank space where I want my G99. My other posts are fine but this one doesn't cooperate!
@chris.coleQDYFL
Thanks!
Max
Message 4 of 11
chris.coleQDYFL
Hey, Max.
If you don't mind, attach your post, and I will test it on my end.
Chris
Chris Cole
Message 5 of 11
m.laplante.gm
Hi Chris,
here's my post
Max
Message 6 of 11
chris.coleQDYFL
Sorry Max, but not seeing an attachment on this end.
Chris
Chris Cole
Message 7 of 11
m.laplante.gm
sorry, the forum does not support .CNC
with file in txt format
(just rewrite cnc as extension)
thanks,
Message 8 of 11
chris.coleQDYFL
Still not coming through, so why don't you just email it to me. chris.cole@autodesk.com
Chris Cole
Message 9 of 11
m.laplante.gm
Hi Chri,
I rewrote my post, testing each modification instead of batching them.
I found that it's glitching when I move the command before
the command.
I usually program: G99 G81 ... It seems that I have to output: G81 G99 ...
I didn't test yet. I hope the machine's gonna be happy with it!
thanks!
Max
Message 10 of 11
chris.coleQDYFL
Sounds good!
Chris Cole
Message 11 of 11
Andrea_SoluzioniCNC
I have the same problem.
CYCLE-RTRCT don't work with turning features but only with mill features, so if the turning hole is the first operation the value of CYCLE-RTRCT is a space.
I forced the value of CYCLE-RTRCT at the beginning with: "[:<CYCLE-RTRCT> = "G98"]".
