FeatureCAM with Solidworks PDM
cclark
cclark
Is anyone else using FeatureCAM with Solidworks and Solidworks PDM? We recently moved to Solidworks and thier PDM system for all of our CAD data. Everytime I try importing a file from the PDM Vault it crashes FeatureCAM. I don't believe we are the only company out there doing this.
I am running FC V2018.2.0.119 and Solidworks 2017.
Our ultimate goal is to have FC part files saved in the Vault also.
Anyone?
0 Me gusta
Responder
902 Vistas
3 Respuestas
Respuestas (3)
bartmann_in_MN
Just tried it.  Worked for me.  Did a drag and drop of a 2017 .SLDPRT file from Vault into FeatureCAM and no problems.
0 Me gusta
cclark
What version of PDM are you using? My original post is a little misleading. I can import from the vault no problem. The issue is when I go to save a part file or import additional models, the open/save dialog opens in a vault directory, if I try to navigate to any other directory FC crashes at this point. Can you save your part file to a different directory after importing the model? So I just did some testing. I usually import models by using the import command. I tried dragging the model in then saving it to a vault directory and it worked. The problem has something to do with navigating around the open/save dialog if it opens in a vault directory. Thanks for pointing this out. https://www.screencast.com/t/t755YqSxh3l
0 Me gusta
bartmann_in_MN
0 Me gusta
