Featurecam 2018 Update
I just updated one of my computers out on the floor and now the keys do not work for placing the part into different views.  I am talking about the CTRL+1 for isometric view and the others.  That has stopped working.  Is there a setting that got turned off that I can turn back on?
graham.goodier
Hi there,
Just before I suggest any other solutions, is it possible you have Num Lock turned on on your keyboard?
Graham Goodier
Product Specialist
marc-andre.jean
Hi @jgabelYM8TK,
first time that you open FeatureCAM after a new install or update, run it as administrator. After opening FeatureCAM for the first time, it's not necessary to run it always as administrator. Most of the time, this solution will fix some issues link with the interface issue or add-ins.
If you still have a problem with your shortcuts, you will need to reset all shortcuts. See the video attached, it explain how you can reset the shortcuts in FeatureCAM.
These steps will restore the basis FeatureCAM shortcuts and allow you the possibility to use the predefined shortcuts for the view like CTRL + 1 for ISO1.
Let me know if it resolves your issue.
Marc-André Jean
Applications Engineer
