Anuncios
Feature cam set up sheet
mjaracuaro9
Community Visitor
mjaracuaro9
Community Visitor
Community Visitor
Fairly new to FeatureCAM so it might be a dumb question but how can I create custom set up sheet templates? I want to add my company logo and make it a little more simple for the operators to read.
0 Me gusta
Responder
363 Vistas
1 Respuesta
Respuesta (1)
serge.quiblier
Hi @mjaracuaro9
If you are using the setupsheet.dll addin delivered with FeatureCAM, it can be done.
When installing the software, a folder called Addins is created, with sub folders inside.
Such sub folder is SetupSheet, that contains the templates for HTML, XML, and XLS output:
You can copy an existing template to any name and folder of your choice.
Then edit it to implement your changes, getting help from the .chm file containing a list of variables accessible in the templates.
Then when you want to generate the setup sheets, Browse for the appropriate template:
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
