does FutureCam have option for Emco Mill 55 ,G-code,Simualtion...
ChristopherMarion
Hi @Anonymous
If you are referring to machine simulation, then the answer is yes.  You would need the 3d model of the machine file in order for this to be done.
If you have it, then you can get your Autodesk partner to create this for you but it will most likely cost you to build it.  I can send you a quote if you'd like since this is a service that we provide.
If you think you can do it yourself, you can use the Machine Design in FeatureCAM to get this working.  Here is some information on how to compile one.
Have a great weekend!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Ok thank you, I think i can do it my self , but thanks again.
