Anuncios
[Do feed reduction for small moves] does not work when setting [TNR Comp]
kotone.ojiri
kotone.ojiri
The function of [Do feed reduction for small moves] does not work when setting [TNR Comp].
Please check the attached FM file.
<turn1>
 - Set [Do feed reduction for small moves]
 - Doesn't set [TNR Comp]
Feed rate value [1.0] which is set in [Do feed reduction for small moves] is output.
<turn2_tnr_comp>
 - Set [TNR Comp]
Feed rate value [1.0] doesn't be output
Do you know this is a bug or an intended move?
(FCAM-3733)
Kotone Ojiri
WWFO-CSO-Technical Consultant
Autodesk |
0 Me gusta
Responder
Soluciones aceptadas (1)
629 Vistas
2 Respuestas
Respuestas (2)
abhishek.juvekar
Solución aceptada
Hi @kotone.ojiri,
Thanks for posting on Forum.
When I was searching on track-record, I found an existing feature request to make it available with TNR. The feature request is Turn: Feed reduction for small moves does not work if nose-R is ON. It is requested to work even wh...
Hope this answers your question. If it does, please click accept as solution button. If it doesn't let me know.
Thank You.
Abhishek
0 Me gusta
kotone.ojiri
Hi @abhishek.juvekar
Thank you for your response. It was very helpful!
Best regards,
Kotone Ojiri
Autodesk |
0 Me gusta
