- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
The function of [Do feed reduction for small moves] does not work when setting [TNR Comp].
Please check the attached FM file.
<turn1>
- Set [Do feed reduction for small moves]
- Doesn't set [TNR Comp]
Feed rate value [1.0] which is set in [Do feed reduction for small moves] is output.
<turn2_tnr_comp>
- Set [TNR Comp]
Feed rate value [1.0] doesn't be output
Do you know this is a bug or an intended move?
(FCAM-3733)
¡Resuelto! Ir a solución.
