Anuncios
Creating a back bore tool
lle
lle
I am having trouble creating a back boring tool. Attached is what I want to draw and use. And also when using a back bore, would I be using a back face in the strategy ? Much appreciated!!
0 Me gusta
Responder
438 Vistas
2 Respuestas
Respuestas (2)
rfuentes
you have to create the geometry on featurecam,make a curve,  then go to new tool, then check "use curve to describe tool shape " and voila.
TomOliver
You will not use back face. It is better to use bore and turning and check toward face instead of toward spindle. After the tool is set correctly, this should work correctly.
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
