Anuncios
Cody
Cody
No aplicable
I have FeatureCam 2013 and just got some Mazak slant turn 450 lathes. they have a PC-Fusion-CNC 640T Mazatrol. I am trying to figure out witch post to use in featurecam to get it to post on my machine.  I have tryed the Mazak power master fanuc 6t.cnc post and it does not seem to work.  Is there a different post any one knows of that will work? Thank you,
cody
0 Me gusta
Responder
248 Vistas
5 Respuestas
Respuestas (5)
No aplicable
What kind of machine? How many turret Upper & lower? Main and Sub Spindle? Axis? XYZ -BC?
Thank you,
Jacob
0 Me gusta
No aplicable
Mazak Slant turn 450 lathe. just 1 upper turret. it has one main spindle and just a x and z axis lathe.
Thank you, Cody
0 Me gusta
No aplicable
In the installation there should be a Mazak_QuickTurn.cnc
C:\Program Files\Autodesk\FeatureCAM 2018\Posts\Turn\Mazak
Thank you,
Jacob
0 Me gusta
No aplicable
I only have one post in the mazak folder of my posts. It is called Mazak_power_master_fanuc_6t.cnc. I do not have the Mazak_QuickTurn.cnc. I also am running feature cam 2013. Is there a different post that will work for me that I have. out side the mazak folder there is hundreds of different posts for different machines and stuff and was wondering if you knew of one of them that would work.   Thank you, Cody
0 Me gusta
No aplicable
Then I think you should try with one of them in the "Fanuc" folder, I would mean this should be the closed to a mazak, but will need some customization.
C:\Program Files\Autodesk\FeatureCAM 2018\Posts\Turn\Fanuc
Thank you,
Jacob
0 Me gusta
