Anuncios
CNC Text
CNC Text
No aplicable
I have some issues to solve regarding the controller DDCSV1 .
  1. I load a plan with the dimention of 400X400mm, the controller causes only 100X100 mm displacement.
 Maybe I'm missing something in the settings, I'd appreciate it if you could guide me through the solution.
  1. The readings I get on the controller display show odd numbers, I measure displacement on the X, Y, Z axis of 200 mm and get about 620 in the display.
              There are also two data on each axis that are not explained in the controller's operating manual.
0 Me gusta
Responder
271 Vistas
2 Respuestas
Respuestas (2)
Patchy
Probably you should ask the CAM group?
https://forums.autodesk.com/t5/featurecam-forum/bd-p/276
0 Me gusta
abhishek.juvekar
Hi @Anonymous,
Welcome to Autodesk Community.
Have you made a program with FeatureCAM, then running it on the machine? If it is, can you please provide the fm file and post-processor?
Thank You.
Abhishek
0 Me gusta
