FeatureCAM Forum
Welcome to Autodesk’s FeatureCAM Forums. Share your knowledge, ask questions, and explore popular FeatureCAM topics.
Change operation strategy with FeatureCAM API
3 REPLIES 3
atomic.lex
396 Views, 3 Replies
Is anybody knows how to change operation strategy with FeatureCAM API?
3 REPLIES 3
serge.quiblier
in reply to: atomic.lex
Hi @atomic.lex
what do you ant to change exactly?
Do you want to convert the Z level operation to something?
Do you want to change the finishing operation to a roughing one?
Or is it the strategies parameters you are after?
Because it won't be the same process and unctions.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
atomic.lex
in reply to: serge.quiblier
Hi Serge,
in this case I have to check and adjust "continuous spiral" if not adjusted and "bottom to top" if necessary.
It would also be great to know how to identify roughing and finishing operations in order to skip them or change them into one another.
Maybe you can also give me an advice how to set the boundary curve via API for the operation.
Thank you for your attention,
Alex
serge.quiblier
Hi @atomic.lex
Here is how some of these actions can be implemented.
You can have a look at the API manual inside FeatureCAM.
Either on the feature level, or the operation level, we can call a function called  setAttributes.
Some of the attributes are :
eAID_DoFinish / eAID_DoRough : a boolean value that is applied at feature level
eAID_FinishStepType / eAID_RoughStepType : an integer value 0 : Spiral vs 1 : ZigZag at operation level
eAID_FinishBottomUp : a boolean that probably represent bottom to top attribute at operation level
I have no idea for the boundary curve, I don't actually know how it's indicated in the operation.
There is a SetCheckSurfaces function but it's for the avoid surface.
There is a setPartSurfaces for what need to be machined.
But I can't identify what can be used to select a boundary curve.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
cam.autodesk.com
