Centerline Text ?
Centerline Text ?
Matthias.K
Centerline Text ?
Matthias.K
in FC TurnMill I'd like to engrave a text on a workpiece. I know there is a way to create a curve from text but afaik this way only outputs the outline of the text. For my purpose what I need is the centerline as a curve.
Is there a way to get a centerline curve from a text?
Alternative: has anyone a working xbuild postprocessor and an UCF that works with Sinumerik 840DSL Cycle60?
Cheers,
Matthias
craig.shipley
Autodesk Support
Autodesk Support
Hi
You need to use the machine tool fonts...
https://knowledge.autodesk.com/support/featurecam/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/FC...
Kind Regards
Matthias.K
Thanks a lot! I've seen and tested these machine tool fonts before but didn't test the output of the Sans Serif one.
