Hi @Anonymous,
How is the stock to machine the actual part? Can you provide 3d models (stock and part) to assist you better?
Thank You
here is a cad i got off from grabcab and thank u for helping me out I`am new at this
Hi @Anonymous,
Thanks for sending the part.
There is no 3d model for stock. So I have used a block stock without any expansion in width, length and height. According to my knowledge, we should keep work offset X and Y at the center of the slot and Z on top of the part for 1st setup as shown in the supplied fm file. You will have to machine that slot though the part which (machined slot)will be used to take work offset on other or back side of part for 2nd setup. Please find the attached fm file with setups created in it and let me know what you think.
Thank you.
thank you for the reply i cant open the fm file
Hi @Anonymous,
Strange! I can download the file and open it successfully. Ok, refer the attached images of setups. For 1st setup, Z offset is on top. For 2nd setup after flipping the part, Z offset is on the machine table.
Thank you.
oky hello i got some files i am going to post to see if this is right dont no about the axis though
first set
oky back side
