Anuncios
c-axis lathe tutorials
No aplicable
Hi is there any PDF tutorial files on using C-axis milling on a lathe for feature cam? im looking for the full tutorial from importing a model, setting the job thro to creating the post. Thanks
0 Me gusta
Responder
Soluciones aceptadas (1)
753 Vistas
1 Respuesta
Respuesta (1)
Christopher_M
Solución aceptada
Hi AC8585,
I think the best place for you to go is to the Instructables site.  From there you get some basic instruction on how to use FeatureCAM turning for free.  Just enroll in the course and go through the material.  This should give you a pretty good understanding of the turning options within the software.  I think there is some turn/mill material in there as well.
If you need more training, you can check out https://mfghub.autodesk.com/ for more information on where the nearest class will be held in your area.
There may also be some information on our YouTube channel for some basic instruction.
Hope this was informative!
Chris M
Applications Engineer
0 Me gusta
