Back Chamfering Holes and Edges
zlancy244
zlancy244
How do you guys back chamfer anything in Featurecam?
There isn't a specific function for it and every attempt i've made to cheat it has been janky.
Thanks for any help.
0 Me gusta
Responder
Soluciones aceptadas (1)
868 Vistas
6 Respuestas
Respuestas (6)
abhishek.juvekar
Solución aceptada
Hello @zlancy244,
There are UDFs (user defined features) in addins library to perform back bore or back chamfer features. Can you please check them if it works for you?
Thank You.
Abhishek
No aplicable
Hello. You identified it as a solution, did it work for you? For me, the tool goes in and out. But the hole is not chamfered from below, since no travel is generated. see link from my post https://forums.autodesk.com/t5/featurecam-forum/add-in-backbore-chamfer/td-p/7828843 . How did you get on with the job? Which solution do you have? Sincerely, Mathias Beyer
Hallo. Du hast es als Lösung gekennzeichnet, hat es funktioniert bei dir? Bei mir fährt das Werkzeug ein und aus. Doch die Bohrung wird nicht von unten angefast, da kein Verfahrweg erzeugt wird. siehe Link von meinem Post https://forums.autodesk.com/t5/featurecam-forum/add-in-backbore-chamfer/td-p/7828843 . Wie bist du an der Stelle weiter gekommen? Welche Lösung hast du? Mit freundlichen Grüßen Mathias Beyer
0 Me gusta
No aplicable
I would be interested in your solution. Can you send data? A * .fm file of your solution? Thank you in advance! Best regards. Mathias Beyer.
Mich würde deine Lösung interessieren. Kannst du Daten schicken? Eine *.fm Datei deiner Lösung? Danke im Voraus! Mit freundlichen Grüßen. Mathias Beyer.
0 Me gusta
jean-francois.landry
Hello @Anonymous
The Add-in is design to work with a back boring bar typically with one offset insert attached to a boring head.
Look this video as reference: https://youtu.be/wAPzspZSPRM
Cheers :cara_con_una_leve_sonrisa:
Jean-Francois Landry
Application Engineer
No aplicable
Thanks for your reply, now I'm enlightened. and additional learning. The knowledge is well laid out on demand.
danke für ihre Antwort, nun bin ich aufgeklärt. Und Zusätzliches gelernt. Das Wissen ist gut angelegt bei Bedarf.
0 Me gusta
zlancy244
I'll post an fm file later with how I was able to achieve a back chamfer. I didn't end up using the addin.
