Hi @hx,
Thanks for providing the version details.
Can you open the bulkedit.wbp from View\Run Basic macro\ bulkedit?
If not, I am attaching a modified copy of the file "FCModule.wbm". Please replace your copy in Addins\BulkEdit with this one. I am attaching it with a text extension. Rename it to FCModule.wbm after downloaded and then replace. Now to run the addin:
1. close FeatureCAM if running
2. You may need to delete the INI file. This is to remove old references to the BulkEdit macro. The file is "EZFM_ui.INI" saved in C:\ProgramData\FeatureCAM
3. run FeatureCAM and from the addins dialog load addins\BulkdEdit\BulkEditProject.wbp
This should bring up the bulkedit menu with the button or from View\Run Basic macro\ bulkedit.
Hope this should solve the problem.
Thank you.
Abhishek
