4th Axis PP Wrong Angles FeatureCAM Ultimate 2022 Ver. 2022.0.3.0018
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am currently running a Haas VF2YT SS/Next Gen controller with a 4th axis setup to rotate around X. The PP I have is the one from Haas and 4th axis is enabled. Inside the XBUILD in the drop down for 'multi axis' I have the "Generic - coordinates are outputted relative to their own setups (no transformations)" set. There isn't another option on there that looks close to what our machine is setup for.
I have a part with drilled holes on each side. The feature for the first set of holes is explicitly located at 90 degrees from the setup. The simulation renders it properly but the GCode it gives us locates the holes at 180 degrees. So instead of it rotating 90 it is rotating 180. It's like this for every feature. I have one hole that is set for 165 degrees but the code it gives says 105.
Why is it acting this way? How do I fix it?
Thank you.
