Anuncios
4th Axis Indexing
4th Axis Indexing
No aplicable
I am Trying to create a post for a Toyoda FH450S horizontal mill. It shows the tombstone (B axis) indexing during simulation, but does not show it in the NC code. I am using Xbuild to create the post and know there are statements to use for indexing, but do not know how to write them? What statement should I write into Xbuild so that it will control the indexing of the B axis? If anyone has a post for this specific machine they would care to share that would be awesome. Any help is appreciated. Thanks in advance
0 Me gusta
Responder
Soluciones aceptadas (1)
730 Vistas
4 Respuestas
Respuestas (4)
zlancy244
Try taking a look at the Haas post processor. It is 4x enabled, and it may give you some insight on what is needed inside of the post to get the functionality working.
0 Me gusta
No aplicable
Even with a 4th axis enabled PP it does not show me that the B axis (tombstone) is indexing. It does show it indexing during simulation but does not generate code that would actually make it index.
0 Me gusta
bhorstTGM48
https://www.screencast.com/t/oDXz95G5aU
It will not output any B axis moves if this in not turned on.
zlancy244
Solución aceptada
The Haas 4x PP is setup to index the A-Axis, so you will not see any B-Values in your code if you have that post selected. I just meant that you should look at the PP to see the logic that is needed to index an axis.
0 Me gusta
