Anuncios
3D spiral surface milling
No aplicable
Can someone help me create this tool path properly? I want to plunge in the open center of a pipe and continually climb mill spiral out with a .015" step over.  I cant seem to figure it out. the tool will not feed in from center and wants to plunge into the material multiple times. Its just a simple end cope for a  4" titanium pipe. the tool
Thank you!
0 Me gusta
Responder
548 Vistas
7 Respuestas
Respuestas (7)
No aplicable
Dave I have a work around for you. I tried several different ways to create the path the way you want it. What I came up with was to change the process to a Z level finish operation rather than a 3d spiral. I would have thought a 3d spiral would have worked great for this pat too but for some reason it wanted to plunge several times before it would begin doing the spiral path. Oh the other thing I had to modify was the Z end on the milling tab. I used .340 Hope this helps and sorry I didn't see this sooner.
0 Me gusta
No aplicable
yes. z level finish continuous toolpath but tool movement  is not smooth . I attach image here, some time I get same issue while od stock is not enough I get x and y movement .(not straigt toolpath). I adjust stock also I get same issue. anyone try and tell me . how to improve this ?
0 Me gusta
abhishek.juvekar
Hi @Anonymous ,
Thanks for posting on Autodesk Forum.
I have created a toolpath using between two curves and given a pocket center lead in/out. Take a look and let me know if you have any questions.
If my post answers your query, please click on accept as solution button.
Thank You.
Abhishek
No aplicable
yes. this tool path is good .but tool engage (step over ) is same point. any idea to remove this tool marks?
No aplicable
kudos really nice job abhishek.juvekar
0 Me gusta
No aplicable
I can see using this on several parts we make
0 Me gusta
No aplicable
Thank you for the help abhishek.juveka!!!
0 Me gusta
