22 second delay when Tools tab is accessed
jeff.brower
jeff.brower
Anybody having delay issues when accessing the Tools tab?
This happens when a file is opened, or when selecting an operation when the Tools tab is active or becomes active.
If I right click on an operation in the Operation List and select 'Tools' then there is a 22 second delay when opening the operation, if I right click in the Operation List and select 'Feeds and Speeds' it opens without delay, then if I select the 'Tools' tab there is a delay.
Different tool cribs or changing the crib yields the same delay, happens on mill or turn parts.
any help is appreciated, thanks!
Jeff
0 Me gusta
Responder
Soluciones aceptadas (1)
642 Vistas
9 Respuestas
Respuestas (9)
ChristopherMarion
Hi @jeff.brower
Are you using an MS Access or SQL database? or are you using a local database?
I've heard this happening with a shared database.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
0 Me gusta
jeff.brower
Local database, installed the 2021 version of FC a month or so back, but this just started a few days ago...
Thanks!
0 Me gusta
ChristopherMarion
Hi @jeff.brower
I would try resetting your INI file.  I am wondering if this is causing the issue.
Here is a good article on how this is done....Resetting the FeatureCAM ini file
Let us know if this helps.
Christopher Marion
SolidCAD - Canada
0 Me gusta
jeff.brower
Thank you Christopher, but this did not solve the issue. I've also re-initialized the database and no luck there either.
Next step is to see if our IT dept can re-install the software.
Thanks again,
Jeff
0 Me gusta
ChristopherMarion
Hi @jeff.brower
What happens if you change the material type?  Try using one of the default FeatureCAM material.....like Aluminum.
I've seen something like this in the past, but I cannot remember what the trigger was.
Christopher Marion
SolidCAD - Canada
0 Me gusta
jeff.brower
No luck there either, the delay seems to be when the software needs to access the tools database...
0 Me gusta
jeff_brower
Solución aceptada
Our AV software was the culprit in this case, thanks for you're help!
0 Me gusta
ChristopherMarion
Hey @jeff.brower
Good to know.
I think you should add a solution to yourself since you were able to find the issue.  This also helps others that may find themselves in the same situation.
Cheers,
Christopher Marion
SolidCAD - Canada
0 Me gusta
jeff.brower
Thanks Christopher!
0 Me gusta
