2018 partmaker back turn problem
I'm trying to back turn a internal bore and I am fighting with partmaker. it allows me to build a back turn tool. and I can create a good finish pass using contour cycle. my problem is trying to rough using a back turn, it shoots my tool into the part before going to the start point. I have tried playing with the user defined cutting point numbers, but that doesn't change it. I'm thinking there is a bug in the software. take a look at the attached pictures.
let me know if there is a work around
thanks!
Nick Martin
phil.jenningsM7ZMZ
 Hi Nem77gf8,
 could you please send me your files. there is a blue telephone icon at the top of the page that will gather and zip your files. then you can send them to me
phil.jennings@autodesk.com
i will set you up with a support ticket and take a look at your case.
thank you,phil
Philip Jennings
Technical Support Team Leader
ChrisDPCnc
Have you tried adding approach/escape points to the front of the bore ?
