Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
UseDepthOfField not having any effect
1 REPLY 1
291 Views, 1 Reply
Hi all, how to turn on 'Depth of Field' in Maya (not in any renderer)? Even if I set it using 'UseDepthOfField.Set(True)' in python and even if the generated FBX has 'P: "UseDepthOfField", "bool", "", "",1' the Depth of Field is actually not turned on in Maya. Is there any solution for it? Thank you!
1 REPLY 1
regalir
The UseDepthOfField property of the FBX is only used by MotionBuilder. Although Maya do have a DeptOfField section, not all the values in that section can be stored in the FBX format (F-stop and Focus Region Scale). Therefore, instead of offering only a partial support, the DeptOfField section of a Maya camera would simply not be supported during an Export to FBX (nor Import)
