I got Python script, which can get Vertex Position, Vertex Indices, but UV and Normals it get uncorrectly, i don't understand what is the problem. Can u help me please guys, i'm figured, really don't know what to do.
Script:
import sys, os, json, urlparse sys.path.append( '/home/o/oddbear/fairmotion/public_html/engine/utils/fbx/lib/Python27_ucs4_x64/' ) from fbx import * def application( environ, start_response ): #url path value = environ[ 'HTTP_HOST' ]+environ[ 'REQUEST_URI' ] query = urlparse.urlparse(value).query.decode( 'UTF-8', 'strict' ) url = urlparse.parse_qs(query)[ 'url' ][0] path = '/home/o/oddbear/fairmotion/public_html/engine/'+url #initializing file manager = FbxManager.Create() IOSettings = FbxIOSettings.Create( manager, 'IOSettings' ) manager.SetIOSettings( IOSettings ) scene = FbxScene.Create( manager, 'Scene' ) importer = FbxImporter.Create( manager, 'Importer' ) status = importer.Initialize( path, -1, IOSettings ) JsonReq = [] if( status != False ): #if file exist importer.Import( scene ) importer.Destroy() pFbxRootNode = scene.GetRootNode() objcount = pFbxRootNode.GetChildCount() for i in range( objcount ): #for every object pFbxChildNode = pFbxRootNode.GetChild( i ) pMesh = pFbxChildNode.GetNodeAttribute() if( pMesh == None ): continue geometry = FbxGeometryConverter( manager ) pMesh = geometry.Triangulate( pMesh, True ) attributeType = pMesh.GetAttributeType(); if( attributeType != FbxNodeAttribute.eMesh ): continue polygonCount = pMesh.GetPolygonCount() layerCount = pMesh.GetLayerCount() indices = pMesh.GetPolygonVertices() pVertices = pMesh.GetControlPoints() m_vecIndices = indices m_vecVertices = [] m_vecNormals = [] m_vecUVs = [] m_vecUVIndices = [] UVs = [] #transform node = pMesh.GetNode() lTmpVector = node.GetGeometricTranslation( FbxNode.eSourcePivot ) Position = [ lTmpVector[ 0 ], lTmpVector[ 1 ], lTmpVector[ 2 ] ] lTmpVector = node.GetGeometricRotation( FbxNode.eSourcePivot ) Rotation = [ lTmpVector[ 0 ], lTmpVector[ 1 ], lTmpVector[ 2 ] ] lTmpVector = node.GetGeometricScaling( FbxNode.eSourcePivot ) Scale = [ lTmpVector[ 0 ], lTmpVector[ 1 ], lTmpVector[ 2 ] ] #vertices control_points_count = pMesh.GetControlPointsCount() control_points = pVertices positions = [] for z in range( control_points_count ): tmp = control_points[ z ] tmp = [ tmp[ 0 ], tmp[ 1 ], tmp[ 2 ] ] positions.append( tmp ) if node: t = node.GeometricTranslation.Get() t = FbxVector4( t[ 0 ], t[ 1 ], t[ 2 ], 1 ) r = node.GeometricRotation.Get() r = FbxVector4( r[ 0 ], r[ 1 ], r[ 2 ], 1 ) s = node.GeometricScaling.Get() s = FbxVector4( s[ 0 ], s[ 1 ], s[ 2 ], 1 ) hasGeometricTransform = False if t[ 0 ] != 0 or t[ 1 ] != 0 or t[ 2 ] != 0 or \ r[ 0 ] != 0 or r[ 1 ] != 0 or r[ 2 ] != 0 or \ s[ 0 ] != 1 or s[ 1 ] != 1 or s[ 2 ] != 1: hasGeometricTransform = True if hasGeometricTransform: geo_transform = FbxMatrix( t, r, s ) else: geo_transform = FbxMatrix() transform = None if hasGeometricTransform: transform = geo_transform if transform: for z in range( len( positions ) ): v = positions[ z ] position = FbxVector4( v[ 0 ], v[ 1 ], v[ 2 ] ) position = transform.MultNormalize( position ) positions[ z ] = [ position[ 0 ], position[ 1 ], position[ 2 ] ] for z in range( len( positions ) ): m_vecVertices.extend( positions[ z ] ) #normals for z in range( layerCount ): mesh_normals = pMesh.GetLayer( z ).GetNormals() if( not mesh_normals ): continue normals_array = mesh_normals.GetDirectArray() normals_count = normals_array.GetCount() if normals_count == 0: continue normal_values = [] for l in range( normals_count ): normal = normals_array.GetAt( l ) normal = [ normal[ 0 ], normal[ 1 ], normal[ 2 ] ] normal_values.append( normal ) node = pMesh.GetNode() if node: t = node.GeometricTranslation.Get() t = FbxVector4( t[ 0 ], t[ 1 ], t[ 2 ], 1 ) r = node.GeometricRotation.Get() r = FbxVector4( r[ 0 ], r[ 1 ], r[ 2 ], 1 ) s = node.GeometricScaling.Get() s = FbxVector4( s[ 0 ], s[ 1 ], s[ 2 ], 1 ) hasGeometricTransform = False if t[ 0 ] != 0 or t[ 1 ] != 0 or t[ 2 ] != 0 or \ r[ 0 ] != 0 or r[ 1 ] != 0 or r[ 2 ] != 0 or \ s[ 0 ] != 1 or s[ 1 ] != 1 or s[ 2 ] != 1: hasGeometricTransform = True if hasGeometricTransform: geo_transform = FbxMatrix( t, r, s ) else: geo_transform = FbxMatrix() transform = None if hasGeometricTransform: transform = geo_transform if transform: t = FbxVector4( 0, 0, 0, 1 ) transform.SetRow( 3, t ) for l in range( len( normal_values ) ): n = normal_values[ l ] normal = FbxVector4( n[ 0 ], n[ 1 ], n[ 2 ] ) normal = transform.MultNormalize( normal ) normal.Normalize() normal = [ normal[ 0 ], normal[ 1 ], normal[ 2 ] ] normal_values[ l ] = normal m_vecNormals.append( normal_values ) #UVs for z in range( layerCount ): mesh_uvs = pMesh.GetLayer( z ).GetUVs() if( not mesh_uvs ): continue uvs_array = mesh_uvs.GetDirectArray() uvs_count = uvs_array.GetCount() if( uvs_count == 0 ): continue uv_values = [] uv_indices = [] for l in range( uvs_count ): uv = uvs_array.GetAt( l ) uv = [ uv[ 0 ], uv[ 1 ] ] uv_values.append( uv ) vertexId = 0 for p in range( polygonCount ): poly_size = pMesh.GetPolygonSize( p ) poly_uvs = [] for v in range( poly_size ): control_point_index = pMesh.GetPolygonVertex( p, v ) if mesh_uvs.GetMappingMode() == FbxLayerElement.eByControlPoint: if mesh_uvs.GetReferenceMode() == FbxLayerElement.eDirect: poly_uvs.append(control_point_index) elif mesh_uvs.GetReferenceMode() == FbxLayerElement.eIndexToDirect: index = mesh_uvs.GetIndexArray().GetAt( control_point_index ) poly_uvs.append( index ) elif mesh_uvs.GetMappingMode() == FbxLayerElement.eByPolygonVertex: uv_texture_index = mesh_uvs.GetIndexArray().GetAt(vertexId) if mesh_uvs.GetReferenceMode() == FbxLayerElement.eDirect or \ mesh_uvs.GetReferenceMode() == FbxLayerElement.eIndexToDirect: poly_uvs.append( uv_texture_index ) elif mesh_uvs.GetMappingMode() == FbxLayerElement.eByPolygon or \ mesh_uvs.GetMappingMode() == FbxLayerElement.eAllSame or \ mesh_uvs.GetMappingMode() == FbxLayerElement.eNone: return '[]' vertexId += 1 uv_indices.append( poly_uvs ) UVs.extend( uv_values ) m_vecUVIndices.extend( uv_indices ) for z in range( len( m_vecUVIndices ) ): for v in range( len( m_vecUVIndices[ z ] ) ): m_vecUVs.extend( UVs[ m_vecUVIndices[ z ][ v ] ] ) #Request JsonReq.append( { 'indices': m_vecIndices, 'normals': m_vecNormals, 'UV': m_vecUVs, 'vertices': m_vecVertices, 'transform': [ Position, Rotation, Scale ] } ) JsonReq = json.dumps( JsonReq ) status = '200 OK' response_headers = [ ( 'Content-type','text/plain' ) ] start_response( status, response_headers ) return JsonReq
