Non-blocking Callback
RvBGames
RvBGames
I haven't figured out how to make this work. The callback is set to a user-defined function:
importerContext.itsFbxImporter->SetProgressCallback(pFbxCallback, this);
The import is started in non-blocking mode:
importerContext.itsFbxImporter->Import(pFbxScene, bNonBlocking)
My callback is called repeatedly and reaches 100%:
bool ImportCallback(void* pArgs, float percentage, const char* pStatus)
    FbxSceneImporter* pThis = reinterpret_cast<FbxSceneImporter*>(pArgs);
    if (pThis == nullptr) return false;
    if (!pThis->GetIsNonBlocking())
        return true;
    FbxImporter* pImporter = pThis->GetImporterContext().itsFbxImporter;
    if (pImporter == nullptr)
        pThis->SetThreadState(FileIOCommon::ThreadState::ImportFailed);
        return false;
    bool bImportStatus = false;
    bool bImporting = pImporter->IsImporting(bImportStatus);
    //if (!bImporting || percentage >= 100.0)
    if (bImportStatus)
        fbxsdk::FbxStatus fbxStatus = pImporter->GetStatus();
        string errorString = fbxStatus.GetErrorString();
        pThis->GetErrorList().push_back(errorString);
        if (fbxStatus != FbxStatus::eSuccess)
            return false;
        pThis->SetThreadState(FileIOCommon::ThreadState::ImportComplete);
    return true;
bImportStatus is never true. Percentage does reach 100% and I can check the status thereafter. But when I return from my function an exception is thrown.
Access violation (0c00..5) in FbxGlobalLightSettings::RestoreDefaultSettings()
Apparently code is accessing a nullptr
I can import without any problems using blocking. Non-blocking is causing me a problem.
Btw, do you have an example that shows how to use FbxProgress? I really didn't find much information on it.
Thank you in advance for your help.
Replies (0)
