FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
How to Scale A node Using FBX SDK python or C+
1 REPLY 1
andrestronic12
717 Views, 1 Reply
Hi comunity.
In this moment I'm Working in a project using Fbx Files for get mesh for my Game Engine, after I need to draw this Mesh. For now I can get the mesh, the vertices and spaces points and draw normality but I need to scaling this meshes before drawing, I know, I can make that, Multiply the matrix or spaces Points by a Scaling MAtrix. but reading the python classes, FBxNode Class have LclScaling.Set(fbxDouble3) here is and example using cubeMan in python
Sorry for my english but please Try to help me
import fbx
import sys
import numpy as np
filepath = 'cubeMan.fbx'
manager = fbx.FbxManager.Create()
importer = fbx.FbxImporter.Create(manager, 'myImporter')
status = importer.Initialize( filepath )
list = []
if status == False:
    print('FbxImporter initialization failed.')
    print('Error: %s' % importer.GetLastErrorString())
    sys.exit()
scene = fbx.FbxScene.Create( manager, 'myScene' )
importer.Import(scene)
importer.Destroy()
a = scene.GetNodeCount()
for i in range(0, a):
    b = scene.GetNode(i)#Obtengo los nodos del archivo FBX
    print(b.GetName())#Imprimo cada uno de los nodos
#Scaling Here doesn't work
t = fbx.FbxDouble3(0.5, 0.5, 0.5)
b = scene.GetNode(1)
b.LclScaling.Set(t)
f = b.GetGeometry()
print(f.GetControlPointAt(0))
c = scene.GetGeometry(0)#Obtengo la geometria de la malla 0
c.GetPolygonVertices()#De esta maneta obtengo los vertices, la triangulacion de la malla
for i in range(0, c.GetControlPointsCount()):#Obtengo los puntos en el espacio de la malla
        list1 = []
        q = c.GetControlPointAt(i)#obtengo XYZ el vector fbx4
        list1.append(q[0])
        list1.append(q[1])
        list1.append(q[2])
        list.append(list1)
n = np.array(list, np.float32)
print(n)
  in the line 28 to 32 I get the first node, after I scale by fbx.double3(0.5, 0.5, 0.5), inmediatily I print the new values but when I get the geometry of that node the values is the same of the original values, Values no change.
Please I need to do that, I'm trying this for too many days I can't do that Need help. sorry for my english is not my first language
Tags (4)
1 REPLY 1
Hi.
if anyone needs to make this here is an example.
* Get the parent or child Node from scene
* Active transformation
b.ScalingActive.Set(1)
 *Apply transformation
px = fbx.FbxDouble3(0.5, 0.5, 0.5)
b.LclScaling.Set(px)
 *Get the Node's Matrix transformation
TransforMatrix = fbx.FbxMatrix(b.EvaluateGlobalTransform())
*When you get the matrix tranformation you can Multiply the mesh Space Vectors for the Matrix transformation
