FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
File does not convert to FBX
5 REPLIES 5
11978 Views, 5 Replies
Here is a skinned Maya mesh that I cannot convert to FBX format. It is a simple skinned mesh derived from the dude.fbx file.
When comverting , I get this error message
"The plug-in has detected mesh nodes with unsupported operators that affect the vertex and/or face count. To correct this, delete the Non-deformer history before exporting. The following nodes will not be processed:
polySurface14"
but if I delete the non-deformer history, that breaks the model so it can't be exported either.
man.zip
5 REPLIES 5
viviane.rochon
Hi Doug,
You have to find a way to modify the mesh while using operators that are supported by the FBX Exporter - here, some operators are changing the vertex count or face count and the FBX Exporter can't process them. You can see this as a limitation of the FBX Exporter. I am sorry that I don't know Maya enough to help you more, maybe there is a way to bake node history into the mesh?
Viviane
Viviane Rochon Montplaisir
Hi Doug,
Viviane
Respectfully, I don't think you should have to go through hoops to save files in an interchange file format. It defeats the whole purpose.
go to
EDIT > DELETE BY TYPE > HYSTORY
EDIT > DELETE  BY TYPE > NO DEFORMER - HYSTORY
also
EDIT > DELETE All BY TYPE > HYSTORY
EDIT > DELETE  All BY TYPE > NO DEFORMER - HYSTORY
Wouldn't doing that make the model lose animations rig and frames ?
