FbxQuaternion.ComposeSphericalXYZ() and FbxAMatrix.GetQ() give different results
For a given input quaternion, if I convert to Euler angles and then back again I sometimes get different answers depending on which method I use.
For example, if I run the following code using the Python 2.7 SDK bindings:
import FbxCommon
quat_in = FbxCommon.FbxQuaternion( 0.10852469361474122, 0.10345202623008598, 0.988614142779236, 0.01273364997133784)
# Convert to Euler XYZ
euler = quat_in.DecomposeSphericalXYZ()
# Convert back to quat using ComposeSpherical()
quat_out_compose = FbxCommon.FbxQuaternion()
quat_out_compose.ComposeSphericalXYZ( euler )
# Convert back to quat using GetQ()
amat = FbxCommon.FbxAMatrix()
amat.SetR( euler )
quat_out_getq = amat.GetQ()
print("quat_in:          ", list(quat_in))
print("quat_out_compose: ", list(quat_out_compose))
print("quat_out_getq:    ", list(quat_out_getq))
I get this output:
('quat_in:          ', [0.10852469361474122, 0.10345202623008598, 0.988614142779236, 0.01273364997133784])
('quat_out_compose: ', [0.10852469361474362, 0.10345202623008602, 0.9886141427792358, 0.012733649971338119])
('quat_out_getq:    ', [0.13700585122690487, -0.0873827401610901, 0.9647038615115937, -0.20721996292864864])
Shouldn't these match? This is an issue for me because my files are being read by a program that uses GetQ() and the resulting animations are incorrect.
regalir
The "problem" with Euler angles is that they can be defined with multiple combinations, therefore, it cannot be guaranteed that in the conversion : Q -> Euler -> Matrix -> Q, the Matrix represent the actual rotation that the input quaternion does.  Some inputs will indeed resolve the above conversion to the same value.
For example:
Q=[0.3826834, 0, 0, 0.9238795] -> Euler=[45, 0, 0] -> Matrix=[ 1, 0.000, 0.000    -> Q=[0.3826834, 0, 0, 0.9238795]
        0, 0.707, -0.707
        0, 0.707,   0.707]
However, in the cases where the rotations cross the 90 or 180 degrees, the Rotation matrix will give an equivalent rotation.
This is what happens in your case:
Q=[0.10852469361474122, 0.10345202623008598, 0.988614142779236, 0.01273364997133784]
Euler=[166.61, -166.81, 25.9]
Matrix=[-0.876  -0.423,  0.228
                 0.375, -0.898, -0.225
                 0.300, -0.111,  0.947]
This matrix represent a rotation vector of [-13.384, -13.186, -154.199] (one equivalent solution to Euler) hence, getting the quaternion back from this matrix will give you a different value from the input one.
A quick search on the WEB, returned me this tool that helps to visualize Euler Angles and Rotation matrix:
http://danceswithcode.net/engineeringnotes/rotations_in_3d/demo3D/rotations_in_3d_tool.html
