Announcements
FBX SDK - How do I export a polygon with a hole in the middle?
Hi there.
I'm trying to make a hole with FbxLayerElementHole class.
But I have no idea to make it.
Followings are the code that I modified from CreateCube sample.
There are 2 rectangules. Bigger one is outter contour, and smaller one is inner contour(hole).
Lee
FbxNode* CreateHole(FbxScene* pScene, char* pName)
    int i, j;
    FbxMesh* lMesh = FbxMesh::Create(pScene,pName);
    FbxVector4 lControlPoint0(-50, 0,   50);
    FbxVector4 lControlPoint1(50,  0,   50);
    FbxVector4 lControlPoint2(50,  0,   -50);
    FbxVector4 lControlPoint3(-50, 0,   -50);
    FbxVector4 lControlPoint8(-25, 0,   25);
    FbxVector4 lControlPoint9(25,  0,   25);
    FbxVector4 lControlPoint10(25,  0,   -25);
    FbxVector4 lControlPoint11(-25, 0,   -25);
    FbxVector4 lNormalYPos(0, 1, 0);
    // Create control points.
    lMesh->InitControlPoints(8);
    FbxVector4* lControlPoints = lMesh->GetControlPoints();
    lControlPoints[0]  = lControlPoint0;
    lControlPoints[1]  = lControlPoint1;
    lControlPoints[2]  = lControlPoint2;
    lControlPoints[3]  = lControlPoint3;
    lControlPoints[4] = lControlPoint8;
    lControlPoints[5] = lControlPoint9;
    lControlPoints[6] = lControlPoint10;
    lControlPoints[7] = lControlPoint11;
    // Set the normals on Layer 0.
    FbxLayer* lLayer = lMesh->GetLayer(0);
    if (lLayer == NULL)
        lMesh->CreateLayer();
    // We want to have one normal for each vertex (or control point),
    // so we set the mapping mode to eByControlPoint.
    FbxLayerElementNormal* lLayerElementNormal= FbxLayerElementNormal::Create(lMesh, "Normal");
    lLayerElementNormal->SetMappingMode(FbxLayerElement::eByControlPoint);
    // Set the normal values for every control point.
    lLayerElementNormal->SetReferenceMode(FbxLayerElement::eDirect);
    lLayerElementNormal->GetDirectArray().Add(lNormalYPos);
    lLayer->SetNormals(lLayerElementNormal);
    // Array of polygon vertices.
    int lPolygonVertices[] = { 0, 1, 2, 3, 4, 5, 6, 7};
    // Create UV for Diffuse channel.
    FbxLayerElementUV* lUVDiffuseLayer = FbxLayerElementUV::Create(lMesh, "DiffuseUV");
    lUVDiffuseLayer->SetMappingMode(FbxLayerElement::eByPolygonVertex);
    lUVDiffuseLayer->SetReferenceMode(FbxLayerElement::eIndexToDirect);
    lLayer->SetUVs(lUVDiffuseLayer, FbxLayerElement::eTextureDiffuse);
    FbxVector2 lVectors0(0, 0);
    FbxVector2 lVectors1(1, 0);
    FbxVector2 lVectors2(1, 1);
    FbxVector2 lVectors3(0, 1);
    lUVDiffuseLayer->GetDirectArray().Add(lVectors0);
    lUVDiffuseLayer->GetDirectArray().Add(lVectors1);
    lUVDiffuseLayer->GetDirectArray().Add(lVectors2);
    lUVDiffuseLayer->GetDirectArray().Add(lVectors3);
    //Now we have set the UVs as eIndexToDirect reference and in eByPolygonVertex  mapping mode
    //we must update the size of the index array.
    lUVDiffuseLayer->GetIndexArray().SetCount(8);
    // Create polygons. Assign texture and texture UV indices.
    for(i = 0; i < 2; i++)
        // all faces of the cube have the same texture
        lMesh->BeginPolygon(-1,-1,-1,false);
        for(j = 0; j < 4; j++)
            // Control point index
            lMesh->AddPolygon(lPolygonVertices[i*4 + j]);
            // update the index array of the UVs that map the texture to the face
            lUVDiffuseLayer->GetIndexArray().SetAt(i*4+j, j);
        lMesh->EndPolygon ();
    // Set material indices
    FbxLayerElementMaterial* lMaterialLayer = FbxLayerElementMaterial::Create(lMesh, "MaterialIndices");
    lMaterialLayer->SetMappingMode(FbxLayerElement::eByPolygon);
    lMaterialLayer->SetReferenceMode(FbxLayerElement::eIndexToDirect);
    lLayer->SetMaterials(lMaterialLayer);
    for (int i = 0; i < 2; i++)
        // the i-th material on FbxNode is applied to the i-th polygon
        lMaterialLayer->GetIndexArray().Add(i);
 FbxLayerElementHole* lHole = FbxLayerElementHole::Create(lMesh, "Hole");
 lHole->SetMappingMode(FbxLayerElement::eByPolygon);
 lHole->SetReferenceMode(FbxLayerElement::eIndexToDirect);
 lLayer->SetHole(lHole);
 lMesh->SetPolyHoleInfo(0,true);
 for (int i = 4 ; i < 8 ; i++)
  lHole->GetIndexArray().Add(i);
    // create a FbxNode
    FbxNode* lNode = FbxNode::Create(pScene,pName);
    // set the node attribute
    lNode->SetNodeAttribute(lMesh);
    // set the shading mode to view texture
    lNode->SetShadingMode(FbxNode::eTextureShading);
    // rescale the cube
    lNode->LclScaling.Set(FbxVector4(0.3, 0.3, 0.3));
        // Add node to the scene
    pScene->GetRootNode()->AddChild(lNode);
    // return the FbxNode
    return lNode;
Replies (0)
