FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
FBX SDK Animation Curve Interpolation Problem
0 REPLIES 0
Message 1 of 1
723 Views, 0 Replies
Hello guys,
I'm using FBX C++ SDK to convert some animation data to FBX. When i use eInterpolationConstant there is no problem. Then i use eInterpolationLinear or eInterpolationCubic and something goes wrong.
Here is my main problem;
I have another problem;
When i'm importing the fbx file i converted, there is 992 keys appear. But i think it is a problem. Because when im importing with checked "Use Default Sample Rate(30 FPS)" option  OR i import blender fbx file then export and import again unreal it shows 25 FPS and there is no change in the animation.
Default(992)
With option(30)
And there are no changes. Sorry for bad english.
Code to check interpolation:
for (int k = 0; k < TrackCount; ++k)
	FbxNode* skel_node = skel_n_map.find(Track[k]->Name);
	FbxAnimCurve* rot_curve_x = skel_node->LclRotation.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_X, true);
	FbxAnimCurve* rot_curve_y = skel_node->LclRotation.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_Y, true);
	FbxAnimCurve* rot_curve_z = skel_node->LclRotation.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_Z, true);
	FbxAnimCurve* pos_curve_x = skel_node->LclTranslation.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_X, true);
	FbxAnimCurve* pos_curve_y = skel_node->LclTranslation.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_Y, true);
	FbxAnimCurve* pos_curve_z = skel_node->LclTranslation.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_Z, true);
	FbxAnimCurve* scale_curve_x = skel_node->LclScaling.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_X, true);
	FbxAnimCurve* scale_curve_y = skel_node->LclScaling.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_Y, true);
	FbxAnimCurve* scale_curve_z = skel_node->LclScaling.GetCurve(anim_layer, FBXSDK_CURVENODE_COMPONENT_Z, true);
	rot_curve_x->KeyModifyBegin();
	rot_curve_y->KeyModifyBegin();
	rot_curve_z->KeyModifyBegin();
	for (int i = 0; i < OrientationKeyCount; ++i)
		// orientation is quaternion data.
		FbxQuaternion rotquat(
			OrientationKey[i]->orientation[0],
			OrientationKey[i]->orientation[1],
			OrientationKey[i]->orientation[2],
			OrientationKey[i]->orientation[3]
		FbxAMatrix rotation_matrix;
		FbxVector4 eul_rotation;
		rotation_matrix.SetQOnly(rotquat);
		eul_rotation = rotation_matrix.GetROnly();
		FbxTime crvtime;
		crvtime.SetSecondDouble(OrientationKey[i]->Time);
		int key_index;
		key_index = rot_curve_x->KeyAdd(crvtime);
		rot_curve_x->KeySet(key_index, crvtime, (float)eul_rotation[0], FbxAnimCurveDef::eInterpolationLinear);
		key_index = rot_curve_y->KeyAdd(crvtime);
		rot_curve_y->KeySet(key_index, crvtime, (float)eul_rotation[1], FbxAnimCurveDef::eInterpolationLinear);
		key_index = rot_curve_z->KeyAdd(crvtime);
		rot_curve_z->KeySet(key_index, crvtime, (float)eul_rotation[2], FbxAnimCurveDef::eInterpolationLinear);
	rot_curve_x->KeyModifyEnd();
	rot_curve_y->KeyModifyEnd();
	rot_curve_z->KeyModifyEnd();
	pos_curve_x->KeyModifyBegin();
	pos_curve_y->KeyModifyBegin();
	pos_curve_z->KeyModifyBegin();
	for (int i = 0; i < PositionKeyCount; ++i)
		FbxTime crvtime;
		crvtime.SetSecondDouble(PositionKey[i]->Time);
		int key_index;
		key_index = pos_curve_x->KeyAdd(crvtime);
		pos_curve_x->KeySet(key_index, crvtime, PositionKey[i]->pos[0]);
		key_index = pos_curve_y->KeyAdd(crvtime);
		pos_curve_y->KeySet(key_index, crvtime, PositionKey[i]->pos[1]);
		key_index = pos_curve_z->KeyAdd(crvtime);
		pos_curve_z->KeySet(key_index, crvtime, PositionKey[i]->pos[2]);
	pos_curve_x->KeyModifyEnd();
	pos_curve_y->KeyModifyEnd();
	pos_curve_z->KeyModifyEnd();
	scale_curve_x->KeyModifyBegin();
	scale_curve_y->KeyModifyBegin();
	scale_curve_z->KeyModifyBegin();
	for (int i = 0; i < ScaleKeyCount; ++i)
		FbxTime crvtime;
		crvtime.SetSecondDouble(ScaleKey[i]->Time);
		int key_index;
		key_index = scale_curve_x->KeyAdd(crvtime);
		scale_curve_x->KeySet(key_index, crvtime, ScaleKey[i]->scal[0]);
		key_index = scale_curve_y->KeyAdd(crvtime);
		scale_curve_y->KeySet(key_index, crvtime, ScaleKey[i]->scal[1]);
		key_index = scale_curve_z->KeyAdd(crvtime);
		scale_curve_z->KeySet(key_index, crvtime, ScaleKey[i]->scal[2]);
	scale_curve_x->KeyModifyEnd();
	scale_curve_y->KeyModifyEnd();
	scale_curve_z->KeyModifyEnd();
0 REPLIES 0
