FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
FBX file won't import
1 REPLY 1
nicoCZ3CT
820 Views, 1 Reply
I'm trying to import an FBX file into Maya 2013 and nothing is happening. There is a short progress bar that shows up, but after its finished nothing is imported into the scene (no data nodes either). It gives me no errors or log files. I get the same result when importing into Max 2013.
The file will open when I try viewing it in FBX Review, so I know the file contains the correct data.
I've tried updating to the latest FBX version and restoring to default settings, still nothing. Any help is much appreciated.
Tags (3)
1 REPLY 1
nicoCZ3CT
in reply to: nicoCZ3CT
I believe this is a problem with FBX file versions. Autodesk 2016 products and above seem to export to file version 7.5, which is not compatible with anything below 2016. Is it possible to convert a 7.5 fbx file down to an older version, or am I sunk?
