FBX Converter - "Not enough parameters" error
zmand97
Observer Observer
zmand97
Observer
Observer
When I try converting an ASCII FBX file to binary in the FBX converter, it says “Not enough parameters” in regards to the FBX file. It doesn’t say how many parameters the file has or how many I need for the converter. What should I do?
regalir
The FBXConverter tool is old and, most likely, you are trying to convert an FBX file with a recent version that is not supported by this tool. You can try to call directly the command line tool found in the bin folder 9C:\Program Files\Autodesk\FBX\FBX Converter\2014.1\bin).
you can just type FBXConverter /? for a description of all the options. But you will quickly see that this executable is limited in the supported FBX versions.
To be able to convert a more recent FBX file, you will have to build your own "tool". This is actually easier than it sound, provided you have a minimum skill in building C++ programs. The FBX SDK package comes with a number of sample code that you can look at to be inspired. The only thing you really have to code to convert an ascii FBX to a binary one, is to read the file and right after save it in binary. You can just slightly modify the ConvertScene sample to skip writing to the other formats 😉
Hope this helps!
Regards
