FBX animation on iOS (without Unity)
I want to read 3d model from fbx file and display it within openGL es 2.0 engine on iPhone (not using Unity) and also I want to display animations for read 3d object.
How can i get animations from fbx file?
Currently I able to get list of poses names with, as I understood, coming with transformation matrix, full list of poses in layer, stacks, layers, and a lot of curves.
How this all information can be combined for displaying proper animations?
I also try to parse some info within TakeInfo, but result a little bit strange as for me, for example:
FbxTakeInfo *ltakeInfo = pScene->GetTakeInfo(lAnimStack->GetName()); FbxTime start = ltakeInfo->mLocalTimeSpan.GetStart(); FbxTime end = ltakeInfo->mLocalTimeSpan.GetStop(); self.startTime = start.GetSecondDouble(); self.endTime = end.GetSecondDouble();
here i got start = 0 and end = 0.014 for each of parsed layers, so i guees this is incorrect (fbx file that I want to display contains 1 mesh with simple 5 sec duration animations).
After few hours of investigating I got next things:
For reference this is structure of test obj that i want to display:
Here u can see a lot of bones (more concrete - 19) I able to get (as noted above) a 19 animated obj in list (like names of bone/obj) and 19 groups of curves within 151 frames each (with frame rate 30 exactly 5 sec of anim. - 30*5=150 + 1 last identity matrix).
If I try use each of curve group to my mesh one by one (I able to parse 1 mesh only) I see animation of different part of mesh applied to all mesh (for example vertical rotation or horizontal translation), so I think that this curves in each group should be applied exactly to specific bone and as result i will got animation for my mesh. The problem is that i don't know how to animate only selected bone vertex part only.
Now the problem is how to apply this all animations divided in to separate group specific to bone to whole obj (because I have only one mesh)?
How can I get 1 global curve's list for each frame from list with all curve's groups?
Thanks to this advice I follow instruction within and with that technique I'm able to retrieve list of bone-specific mat's with start and end time and required transforms, but this is almost same like I got before with curves - the only difference that with curves I should create mat from 9 curves (translate/ scale/ rotate for x y z) instead of using full matrix, but problem are still present - how can i combine them in 1 global matrix?
The code that I use (found few links for it):
FbxNode* modelNode = _fbxScene->GetRootNode();
FbxAMatrix geometryTransform = GetGeometryTransformation(modelNode);
for (unsigned int deformerIndex = 0; deformerIndex < numOfDeformers; ++deformerIndex) {
FbxSkin* currSkin = reinterpret_cast<FbxSkin*>(mesh->GetDeformer(deformerIndex, FbxDeformer::eSkin));
if (!currSkin) {
continue;
unsigned int numOfClusters = currSkin->GetClusterCount();
for (unsigned int clusterIndex = 0; clusterIndex < numOfClusters; ++clusterIndex) {
FbxCluster* currCluster = currSkin->GetCluster(clusterIndex);
std::string currJointName = currCluster->GetLink()->GetName();
FbxAMatrix transformMatrix;
FbxAMatrix transformLinkMatrix;
FbxAMatrix globalBindposeInverseMatrix;
currCluster->GetTransformMatrix(transformMatrix);
currCluster->GetTransformLinkMatrix(transformLinkMatrix);
globalBindposeInverseMatrix = transformLinkMatrix.Inverse() * transformMatrix * geometryTransform;
FbxAnimStack* currAnimStack = _fbxScene->GetSrcObject<FbxAnimStack>(0);
FbxString animStackName = currAnimStack->GetName();
char *mAnimationName = animStackName.Buffer();
FbxTakeInfo* takeInfo = _fbxScene->GetTakeInfo(animStackName);
FbxTime start = takeInfo->mLocalTimeSpan.GetStart();
FbxTime end = takeInfo->mLocalTimeSpan.GetStop();
FbxLongLong mAnimationLength = end.GetFrameCount(FbxTime::eFrames24) - start.GetFrameCount(FbxTime::eFrames24) + 1;
for (FbxLongLong i = start.GetFrameCount(FbxTime::eFrames24); i <= end.GetFrameCount(FbxTime::eFrames24); ++i) {
FbxTime currTime;
currTime.SetFrame(i, FbxTime::eFrames24);
FbxAMatrix currentTransformOffset = modelNode->EvaluateGlobalTransform(currTime) * geometryTransform;
FbxAMatrix mat = currentTransformOffset.Inverse() * currCluster->GetLink()->EvaluateGlobalTransform(currTime);
Here I receive 121 matrix instead of 151 - but duration of some matrix transforms take more than duration of 1 frame draw, so the q-ty here I think also correct
float duration = end.GetSecondDouble() - start.GetSecondDouble(); //return 5 as and expected
I guess that that Autodesk SDK there is a way to get 1 Global transform per each drawCall
Any suggestions? Is this possible? Maybe any workable sample available?
