ETA on having fbx sdk lib for new apple silcon ARM
Message 1 of 22
Hi there,
Is it possible to get the fbx sdk libs for the new incoming mac apple silicon ARM platform? If not, is it plan to be supported soon? We want to support this hardware before our client get there hands on this hardware.
Alexis
Replies (21)
Message 2 of 22
regalir
Xcode 12 being released is a pre-requisite therefore Autodesk cannot announce a schedule based on someone else’s beta hardware and beta compiler.
Message 3 of 22
Hi! Xcode 12 actually got released ~3 days after your post. Is there a chance to get a bit more info on when the FBX SDK for Apple Silicon is going to be available then?
Thanks!
Message 4 of 22
ssontech
Right, availability of the AS version is ultimately a release gate item for our commercial software.  Don't need a final version now, but absolutely need a prerelease beta-on-beta version for testing, to be ready to go. Please advise on how/when that can be obtained by PM.  Tnx.
Message 5 of 22
Hi again and sorry for drilling the topic but it would be great to know what developers can expect in the upcoming days/weeks/months. Xcode 12 is out, many developers have access to the Silicon Dev Kit (I assume Autodesk does too) and it would be really helpful if they could at least test their software on this platform. Hope this isn't too big of a problem for the FBX SDK team.
Also, I'm not sure if marking this topic as solved was a good idea since it is clearly not solved.
Message 6 of 22
ssontech
Hey, this isn't going away, this issue isn't "solved", it's not an idle "wouldn't it be nice if" question.... need to get hooked up on this.
Message 7 of 22
daviesm
It is true that Xcode 12 is out and this allows one to build a Universal binary for a APP. The support for building a free standing library with a cmake system (Or Xcode) is still not possible. We are working/waiting on this but do not have an ETA yet.
Mark
Message 8 of 22
Actually, doing this is possible right now and we do it ourselves 🙂
If you want to build a Universal library (for example the open source glog library), all you need to do is set the following flags in cmake:
-DCMAKE_OSX_ARCHITECTURES="arm64" \
-DCMAKE_HOST_SYSTEM_PROCESSOR="arm64" \
-DCMAKE_SYSTEM_PROCESSOR="arm64"
Once it's built, you can combine it with your other (Intel-based) library into a single Universal library by following the steps listed on Apple's website: https://developer.apple.com/documentation/xcode/building_a_universal_macos_binary?language=objc
Of course the tutorial is meant for combining apps but you can also use it for combining libraries, like so:
x86_lib.dylib: main.c
$(CC) main.c -o x86_lib.dylib -target x86_64-apple-macos10.12
arm_lib.dylib: main.c
$(CC) main.c -o arm_lib.dylib -target arm64-apple-macos11
universal_lib.dylib: x86_lib.dylib arm_lib.dylib
lipo -create -output universal_lib.dylib x86_lib.dylib arm_lib.dylib
It works perfectly on our end.
Hope this helps.
Message 9 of 22
ssontech
Building Universal libraries is certainly possible just as @Anonymous says, I've built a number of opensource libraries, plus various executables and the full app... with FBX #ifdef'd out, of course!  Just do it already. 😉
Message 10 of 22
daviesm
On a clean machine with Catalina and Xcode 12.1 installed:
 Fails.
As soon as we can build the SDK with released components we will update you with a release plan.
Message 11 of 22
daviesm
See https://developer.apple.com/download/release/
Xcode 12.1
Xcode 12 includes everything you need to create amazing apps for all Apple platforms. Includes the latest SDKs for iOS, watchOS, and tvOS, and macOS Catalina. For development on macOS Big Sur or to support Apple silicon, continue to use Xcode 12 beta 6.
12.2 might be the one
Message 12 of 22
Yes, you need 12.2 to be able to compile it, I should have clarified that part, sorry. It does work with libraries though 🙂
Message 13 of 22
sandnseapa
Autodesk couldn't scrounge together $500? 😖 I'd think that if you'd asked nicely, Apple might have given some professional courtesy.
Message 14 of 22
daviesm
We have a beta of FBX-SDK for Mac only. This is a universal binary for intel/arm64.
See - https://feedback.autodesk.com/home.html?welcome
Regards
Mark
Message 15 of 22
ssontech
Intel side is compiled against 10.15, needs to be much earlier eg 10.13 ... feedback filed.
Message 16 of 22
artgolf1000
I have tested the beta version on my new Mac mini M1 (16GB Ram, 512GB SSD), and I compiled three projects with the beta version, it works quite well, no issues found.
Message 17 of 22
ssontech
It's done well in my testing also (some large import/exports with/without vertex caches), so per the original question, now looking for an ETA for the release.
Message 18 of 22
Same here, everything seems to work fine.
Message 19 of 22
I can install the SDK but not the Python SDK on M1. Any ideas how I can solve the problem? Otherwise Apples Reality Converter is not running.
Message 20 of 22
daviesm
FBX-SDK 2020.2 supporting Universal binaries for intel and arm, is released today,
https://www.autodesk.com/developer-network/platform-technologies/fbx-sdk-2020-2
Mark
