There is a minor error in the FBX 2017 sample code at http://help.autodesk.com/view/FBX/2017/ENU/?guid=__files_GUID_4E8F95CA_CD9B_4E24_B8AD_7C399EA78137_h...
The line:
bool lExportStatus lExporter->Initialize(lFilename, -1, lSdkManager->GetIOSettings());
should be:
bool lExportStatus = lExporter->Initialize(lFilename, -1, lSdkManager->GetIOSettings());
I noticed a couple of other issues while attempting to report this problem:
Solved by vincent.haubruge. Go to Solution.
Thank you for reporting this. You're right and we will fix that.
You can report a problem in the documentation going at the bottom of every page has a link to Useful Yes/No - which lets you report a problem.
Best Regards,
Vincent
