I am trying to work out the culling mode of objects inside an FBX file. I can't seem to find any references online or otherwise on how to find this information out.
Example Fbx file snippet:
Model: 67229744, "Model::Plane", "Mesh" {
Version: 232
Properties70: {
P: "PreRotation", "Vector3D", "Vector", "",90,-0,0
P: "RotationActive", "bool", "", "",1
P: "ScalingMax", "Vector3D", "Vector", "",0,0,0
Shading: Y
Culling: "CullingOff" // how to get this information
I am using the Python FBX SDK bindings and have tried displaying all the properties of a node I can find:
def displayProperties(node):
prop = object.GetFirstProperty()
while prop.IsValid():
print("{}: {} {} {}".format(node.GetName(), prop.GetLabel(), prop.GetName(), prop.GetPropertyDataType().GetName()))
prop = object.GetNextProperty(prop)
displayProperties(node) // does not contain Culling data
displayProperties(node.GetGeometry()) // does not contain Culling data
displayProperties(node.GetMesh()) // does not contain Culling data
None of the displayed properties contain any culling info.
I know there must be a way to get this data because I can import a file using this SDK, convert it to ascii and I can clearly see the culling information is there.
I have even found the following function:
node.GetShadingMode()
which returns the correct Shading: information stored which seems to be at the same "fbx hierarchical level", but I can find not a single function that tells me the culling state. Any ideas?
Solved by regalir. Go to Solution.
unfortunately there is no way to access/manipulate the Culling value in Python. In the C code, the value is not stored as a property thus, it does not get exposed. Also, this variable is stored in the "undocumented and subject to change without notice" section of the C API class; meaning that, even if you decide to use the FBX SDK C API instead of Python, the variable can disappear anytime (or never 😉
