Correct Form To Animate Mesh Vertices Using FBX SDK Python or C++
andrestronic12
andrestronic12
Hi.
People, in this moment I have a simple model with a simple animation. The model only has four bones, please see the picture.
I'm Working using Fbx Sdk to xtract the data and these are my steps
* First I get the names of the Nodes and get the Spaces Points, Indices of the model Using FbxNode Class. When I import the model is in object space Like this picture.
*When I get the data, I multiply for the world space matrix of the model this matrix is in
GlobalMatrix = MeshNode.EvaluateGlobalTransform()
*Now the model looks bigger
I get the indices of each bone and weights Using FBXSkin class. after I get the datas, I get the Link Matrix of each Bone using.
linkMatrix = FbxAMatrix()
linkMatrix = fbxCluster.GetTransformLinkMatrix(linkMatrix)
 I get the current Matrix of each Node Using
CurrentBoneMatrix = BoneNode.EvaluateGlobalTransform(FbxTime)
Now for example I get the MAtrix of each bone in the Frame Number 20 of the animation and I multiply for each matrix.
FinalPositionMatrix =linkMatrix.Inverse() * GlobalMatrix * CurrentBoneMatrix
but the result is not good.
The model must be inclinated something like this.
But I get this.
I don't Know, What's wrong please Help
@jiayang.xu
ilan.keshet
this line:
I've used EvaluateGlobalTransform in the past, -- at it produces strange results. -- don't use it.
ilan.keshet
You can verify to see if the EvaluateGlobalTransform -- is what is causing you the problem.   Print out the matrix you are getting from it -- and grab the T,R,S  from it -- and compare it to blender / maya / 3ds Max /...  value.    -- It should match what you want to see.  -- Note however, that these T,R,S given back to you are in Global space, -- so if you create a node at the root, with these transformations, it should line up to whatever node you are trying to compare to.
-- Also this calcuation you have done:
Has a similar problem, and should not be used -- instead you can take the Mesh Binding transformation from the Skin Cluster
FbxAMatrix meshBindingTransform;
cluster->GetTransformMatrix(meshBindingTransform);
This will be guarenteed to work.
