I was wondering if anyone had attempted to build an executable from the command line using clang++ that's using the FBX SDK on Windows. Like you could on Linux?
if this is even possible, what would be the steps. Thx)
Solved by jcpSJ5MS. Go to Solution.
Hum I seem to have made it work (but anybody could share his/her experience with this, just in case, I am missing something I would appreciate):
./fbx
Name of the node pSphere1
That's it. I am little confused about the use of md or mt lib. If something could clarify this but, would appreciate.
#include <iostream>
#include <fbxsdk.h>
void PrintNode(FbxNode* pNode)
std::cerr << "Name of the node " << pNode->GetName() << std::endl;
int main(int argc, char **argv)
const char* lFilename = "./sphere.fbx";
FbxManager* lSdkManager = FbxManager::Create();
FbxIOSettings* ios = FbxIOSettings::Create(lSdkManager, IOSROOT);
lSdkManager->SetIOSettings(ios);
FbxImporter* lImporter = FbxImporter::Create(lSdkManager, "");
if (!lImporter->Initialize(lFilename, -1, lSdkManager->GetIOSettings())) {
throw std::runtime_error("call to FbxImporter failed");
FbxScene* lScene = FbxScene::Create(lSdkManager, "myScene");
lImporter->Import(lScene);
lImporter->Destroy();
FbxNode* lRootNode = lScene->GetRootNode();
if (lRootNode) {
for (int i = 0; i < lRootNode->GetChildCount(); ++i) {
PrintNode(lRootNode->GetChild(i));
lSdkManager->Destroy();
return 0;
