Can't view FBX file with Cinema 4D material...
Hi all,
I've exported a simple textured dice model from Cinema 4D to FBX format (2013.3) with embedded material and when I open it in FBX Review nothing is visible. When I export only geometry I can see the model in FBX Review, so the problem must certainly be with Cinema 4D material export...
Is there something special to obtain compatible materials ? (like special naming for example)
Any help would be appreciated...
OK so it seems that the problem is with texture files (pictures) associated with a material : when I assign only a simple color to the model as material, I can see it in FBX Review.
Perhaps I don't place texture file in the good place ? Strange thing : when I open a fbx file with a texture, FBX Review scene information says : 0 polygon...
Moderator could perhaps close this thread as I can't. I've opened another subject more appropriate and more general, because the problem is not only with C4D materials but with every material with a texture (3ds, dxf, obj, fbx) : either i see the model without material, either i don't see any model at all (app info says : 0 polygon)
