can not download offline documents of FBX 2018.1.1
 From this page: http://usa.autodesk.com/adsk/servlet/item?id=24245570&siteID=123112
there listed the offline version of FBX sdk documents. but none of those download link works.
for example this link: http://docs.autodesk.com/FBX/2016/ENU/FBX-Developer-Help/fbx-2018-developer-help.zip
click this link will get a 404 error.
Please fix that, We need the offline version of sdk document. Thanks.
regalir
The links seems to be back online! I had no problem downloading.
I still can not download it, is this because I'm from China? the problem of CDN?
vincent.haubruge
This issue should be resolved.
Best regards,
Vincent
Vincent Haubruge
Tried downloading offline documentation for FBX SDK 2018.1.1 But get a 404 error message instead.
The link on http://help.autodesk.com/view/FBX/2018/ENU/?guid=__files_GUID_CC2D0441_C24A_457A_8C00_878760682B2D_h... also returns
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7478532 (Autodesk Developer Network)
vincent.haubruge
Thank you for your feedback.
Offline downloading of the FBX 2018 help was fixed previously. Looks like the Autodesk Developer Network page itself is not working. We are working to fix it.
Vincentt
Vincent Haubruge
FBX SDK 2016 docs seems to be available for download
http://docs.autodesk.com/FBX/2016/ENU/FBX-Developer-Help/fbx-2016-developer-help.zip
but, FBX 2018 docs' zip file's link
http://docs.autodesk.com/FBX/2018/ENU/FBX-Developer-Help/fbx-2018-developer-help.zip
gives a "File not found" error message.
Can you share the working link for 2018 docs?
