Building FBX SDK on Apple Silicon for Python
Hi Everyone,
I have been trying to build the FBX SDK, with the Python bindings so I can write some plugins in Python that directly interact with raw FBX data.
Any help would be greatly appreciated
I have been trying a few different approaches, each end me up with failure.
The following are the setup steps I take,
OS: Ventura 13.5.2 (22G91)
Macbook Air M1
Python 3.9.7
Setup Process
Error Message
FBXPythonBindings % python3 PythonBindings.py Python3_ub buildsip
=> SRC PYTHON : /Users/Shared/TEMP_DELETE/FBXPythonBindings
=> SCRIPT PATH : /Users/Shared/TEMP_DELETE/FBXPythonBindings
=> BUILD PATH : /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub
=> SDK Headers : ['/Users/Shared/TEMP_DELETE/FBX SDK/2020.3.2/include']
=> Machine Type : arm64
=> LIB PATH : ['/Users/Shared/TEMP_DELETE/FBX SDK/2020.3.2/lib/clang/release']
=> PLATFORM TAG : FBX_X86_X64
=> SIP : /Users/Shared/TEMP_DELETE/sip-4.19.25
=> -=[ Build SIP Module ]=-
=> CURRENT DIR : /Users/Shared/TEMP_DELETE/sip-4.19.25
=> RUN COMMAND : "/Library/Frameworks/Python.framework/Versions/3.9/bin/python3" configure.py -b /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub -d /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub --arch=x86_64 -e /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub
This is SIP 4.19.25 for Python 3.9.7 on darwin.
The SIP code generator will be installed in
/Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub.
The sip.h header file will be installed in
The sip module will be installed in
The sip.pyi stub file will be installed in
The default directory to install .sip files in is
/Library/Frameworks/Python.framework/Versions/3.9/share/sip.
MacOS/X binaries will be created for x86_64.
Creating sipconfig.py...
Creating top level Makefile...
Creating sip code generator Makefile...
Creating sip module Makefile...
=> RUN COMMAND : make clean
rm -f sip
rm -f main.o
rm -f transform.o
rm -f gencode.o
rm -f extracts.o
rm -f export.o
rm -f type_hints.o
rm -f heap.o
rm -f parser.o
rm -f lexer.o
rm -f sip.so
rm -f siplib.o
rm -f apiversions.o
rm -f descriptors.o
rm -f qtlib.o
rm -f threads.o
rm -f objmap.o
rm -f voidptr.o
rm -f array.o
rm -f int_convertors.o
rm -f bool.o
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o main.o main.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o transform.o transform.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o gencode.o gencode.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o extracts.o extracts.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o export.o export.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o type_hints.o type_hints.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o heap.o heap.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o parser.o parser.c
cc -c -pipe -arch x86_64 -Os -Wall -W -DNDEBUG -I. -o lexer.o lexer.c
c++ -headerpad_max_install_names -arch x86_64 -o sip main.o transform.o gencode.o extracts.o export.o type_hints.o heap.o parser.o lexer.o
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o siplib.o siplib.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o apiversions.o apiversions.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o descriptors.o descriptors.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o qtlib.o qtlib.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o threads.o threads.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o objmap.o objmap.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o voidptr.o voidptr.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o array.o array.c
cc -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o int_convertors.o int_convertors.c
c++ -c -pipe -fPIC -arch x86_64 -Os -Wall -W -DNDEBUG -I. -I/Library/Frameworks/Python.framework/Versions/3.9/include/python3.9 -o bool.o bool.cpp
c++ -headerpad_max_install_names -bundle -undefined dynamic_lookup -arch x86_64 -o sip.so siplib.o apiversions.o descriptors.o qtlib.o threads.o objmap.o voidptr.o array.o int_convertors.o bool.o
=> RUN COMMAND : make install
cp -f sip /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sip
cp -f /Users/Shared/TEMP_DELETE/sip-4.19.25/siplib/sip.h /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sip.h
cp -f sip.so /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sip.so
cp -f /Users/Shared/TEMP_DELETE/sip-4.19.25/sip.pyi /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sip.pyi
cp -f sipconfig.py /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sipconfig.py
cp -f /Users/Shared/TEMP_DELETE/sip-4.19.25/sipdistutils.py /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sipdistutils.py
/Library/Frameworks/Python.framework/Versions/3.9/bin/python3 /Users/Shared/TEMP_DELETE/sip-4.19.25/mk_distinfo.py "" /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sip-4.19.25.dist-info installed.txt
=> CURRENT DIR : /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub
=> Sipconfig Path : /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub
=> -=[ Build FBX Module ]=-
=> RUN COMMAND : "/Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/sip" -o -t FBX_X64 -c /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub -b /Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/fbx_module.sbf -I /Users/Shared/TEMP_DELETE/FBXPythonBindings/sip /Users/Shared/TEMP_DELETE/FBXPythonBindings/sip/fbx_module.sip
sip: /Users/Shared/TEMP_DELETE/FBXPythonBindings/sip/fbxtypes.sip:32: syntax error
Error: Unable to open
"/Users/Shared/TEMP_DELETE/FBXPythonBindings/build/Python39_ub/fbx_module.sbf"
