Show only
Search instead for
As you know, the Key parameters is already exported to the part list. is that not working for you to set the needed user parameters as key parameters which will be exported in the part list?
"As you know, the Key parameters is already exported to the part list. is that not working for you to set the needed user parameters as key parameters which will be exported in the part list?"
We do have kind of a similar problem. Every KeyParameter is listed in the Asset Parameters. Not every information which needs to be in the BOM has to be shown in the Asset Parameter. Especially if the Asset has more than 20 Parameter you don't want to have shown 20 other which are only "side" informations which where cause by the "real" key parameter.
