In Inventor drawing views you can change the margin size so you can control how much of referenced parts around the edge of you drawing you wish to see. You don't have a such an option in AutoCAD. This means when using assets in AutoCAD that have a referenced item close the the edge you do not see it in CAD as a dashed line. I'd like this to be changed so it either just shows the entire asset entity or have the option like in Inventor when you can change the margin (I don't think that latter would be that easy to achieve though)
